problem
  • Riyadh hossain
    • Aug 2025
    problem
    How can I know that copier is 32 bit os from factory nor 64 bit bit os from factory ???????? in toshiba e studio 450/452
    • 8229
    Re: problem
    The copier does not use a Windows or iOS processor. It uses a Toshiba eBridge 2 proprietary operating system.
    Your only concern about 32/64 bit is with regards to the PC you are attempting to install print drivers on.
