Do NOT do as suggested above mrban as this is NOT the answer but a way around the real problem for a short while - this will only turn off the Auto Calibration & you will not be able to perform the Manual Cal!
CA00 can be caused by a number of things, dusty Patch Detect Sensors (3), Laser Glasses, depleted Developer in any of the Dev Units, old Drum/s, Grids or faulty Laser Unit/s - clean all of the above, check PM list 6+Start P/ON > 2 > Enter, if above Units are over Life, then replace & perform the required adjustments - if unsure contact a Toshiba Specialist as you will run into big problems & expense.
Hey that came right out the Toshiba Service Manual. lol But in any case try the above first and if that does not work then turn it off according to the manual. What ever works for you. Good Luck
I'm not in this for an arguement sagar4 and you are correct, it is straight out of the manual however only an extract, the full version is about 20 pages long.
