eStudio306 New Fax Module
  • cciardi
    • Jul 2025
    Hi. Computer guy here trying to help out a local charity. They have an eStudio306 which I installed a fax module into. It was a fairly straight forward install, however fax capabilities are not enabled and I suspect it requires firmware, as I see firmware installed for other options like finisher and networking. Am i on the right path? If so, how can I obtain this firmware as Toshiba only shows drivers on their website.
    chris@autismup.org
    Thanks!
    Chris
  • ivovb
    • 695
    Re: eStudio306 New Fax Module
    No firmware needed. Did You get and follow installation instruction along with fax board?
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
    • cciardi
      yes, i followed each step in the installation sequence provided by toshiba. It was quite easy, which is why I was wondering if firmware was needed to enable the module.
      • arnh79
        • 468
        No firmware required. However, you do need to initialize the fax board after installation. Hold down 1 and * while powering up machine and then type 100 and hit start. If that doesn't change anything and you still don't see fax option on the copier then I would assume:
        1) something is unplugged (very easy for ribbon cable inside fax board to come lose)
        2) wrong type of fax board or
        3) defective board.
        Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
        • cciardi
          arnh79 - Worked perfect right after I performed your proceedure. Thanks!!
          • ivovb
            • 695
            But of course - this procedure is part of installation instruction. And it is obvious now that You didn't follow it...
            BR
