hi all !!!
i have the proplem with gl10x0 need to help
i have the cd GL1020partv20 and cd GL1020recovery2125 used to set up gl10x0
HDD is jumped cable select.
i connect monitor and keyboard with gl10x0 when i insert the cd GL1020partv20 into cd rom drive and power on photo machine. Watch the monitor, it boot and run to :
"scsi0:SCSI host adapter emulation for IDE ATAPI divices"
" Kernel panic: VFS: Unable to mount root fs on 16:00"
and it stand here, the led on keyboard is 'link' up.
please hepl me this proplem!!
thanks !
GL-1010/1020 Software update process:
Attach a Monitor to the controller.
Ensure the HDD is at least 40GB in size (Blank HDD Part # 6GA080GBHDD).
Set HDD jumper to Cable Select.
Insert partition CD (Part # 6LA53674000).
Power Off Power On
Wait until partition disc is ejected
Insert Recovery CD Power Off Power On
Update Process Starts automatically
Watch the Monitor for errors and watch the LCD panel to ensure the progress bar does not jump to the end quickly, it should be a steady progression. Otherwise the Install has failed (Possible bad HDD)
Once installation is complete power off and back on.
Check operation.
thanks !
Power Off Power On
Check operation.
