Hi Everyone,
I have setup a template for Toshiba MFP e-Studio 355
However, when I try to scan a document using my customised template it saves 3 copies of pdf files (0kb) on the Windows 2012 server.
I did research on internet and found out that the the MFP or the Server requires a firmware update. Because, the Toshiba scanner uses SMB2 and the Windows 2012 server uses SMB3 which causes the problem. Am I correct on this?
If yes, then please tell me from where can I get a new firmware? or is there any alternative way to fix this problem?
- Can we get it fix from the server end without updating the MFP firmware?
Thank you,
Jay C
Thank you,
Jay C
