In changing hard drive for this model. Does it needs a special application in formatting the HDD? And what would be the maximum hard disk capacity applicable for this model to work at normal speed?
hard drive on E-Studio 600
Re: hard drive on E-Studio 600
I believe you can go up to 120GB, the drive must be formatted and partitioned using the 3/c mode, and you will need to reload UI/HDD data at a minimum, but the full firmware update can't hurt. Follow the firmware update instructions as there are a couple of steps required after the update. EmujoIf you don't see your question answered in the forum, please don't think it's OK to PM me for a personal reply...I do not give out firmware and/or manuals.
