e studio 160
  • bariskurt23
    • 16
    e studio 160
    hi
    how to login e studio 160 simulation mode (service mode) ? 1087 1087 to login kyocera mita how is toshiba ,thanks
  • xcopytech
    • Aug 2006
    • 1792
    Why you need diagnostic mode?
    Suggest to find service manual first?
    Toshiba have several service modes (input check, output check, test print, adjustment, setting mode, etc.)
    Each of them have different entry.
    • deep
      • Jun 2008
      • 208
      Tell us what the problem is. We will help you.
      Kenny
      • bariskurt23
        • 16
        reset pm
        i want reset pm counter
        • deep
          • Jun 2008
          • 208
          It is not recommended to clear the PM counter manually.
          A lot of problems will be arised if you do so.
          Since the PM message will not affect your copier, use it as usual.
          After it is locked up, replace a new Process Unit and the message will be gone automatically.
          Kenny
          • CRAZY_BG
            i amp problem with E studio 160
            part number hot wheel i the fuser
            • Naveed Shahid
              • May 2008
              • 162
              08 689
              • wassimkhm
                xi 8020 code 550
                i haveproplem with mita xi 8020
                the eror massage is550
