some troubleshooting with code : "line adjustment mode"
  • MUMMIM
    • Jan 2008
    • 125
    Hi all !
    I have some the machines for rent, some customers the know " line adjustment mode" code. they changed from "0" to "1" in this code and so the counters doesn't run.
    who can help me know , how can i know the correct counters when they set it?
  • bigwul
    • Jun 2014
    • 60
    Re: some troubleshooting with code : "line adjustment mode"
    Not sure how about recovering the counters - but you can change the Service Password - so it can't be changed....and has to be left at ZERO.
    It seems they know the default password.
    • arnh79
      • 468
      I believe the PM counters still count eve in "Line Mode" so you could reset the counter before each rental and then see if it matches the main meter.
      Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
      • bigwul
        • Jun 2014
        • 60
        Yes - worth a try - do a PM list print - set the line adjust mode to both 0 and 1 - and do a handful of copies - this should tell you.
        • Logged-on
          • Sep 2010
          • 197
          We had one in the field that the meter was turned off, but the check and call still reported accurately.
          • MUMMIM
            • Jan 2008
            • 125
            Hi friend!
            what is the " change the service password" ? pass of the mode 08 ? how can i change it?
            - when the code "line adjustment mode" was stood 1, i think all counters (pm, total, ...) stop .
            - "We had one in the field that the meter was turned off, but the check and call still reported accurately." how did you do , Logged-on ? guide me pls!
            • MUMMIM
              • Jan 2008
              • 125
              Originally posted by MUMMIM
              Hi friend!
              up up...
              up up
