As the title says, I have c56 code. I have checked all the connections on the Main and PFC pcb's. I did find a frame ground connector not connected ( I highly doubt that has anything to do with the problem but thought it was worth mentioning) and reconnected it. Do these machines have a tech mode to reset errors and if so how does one access it? I did look in the service manual but all I was able to find was "reset memory" mode. Using the procedure to access that mode wouldnt work, so I am guessing that wouldnt solve the problem anyway. The manual says replace the Main and/or PFC pcb. Has anyone had one of these pcb's go? Is there something else I should be looking for?
Thanks in advance ... you guys and gals here usually will come through for me on this forum
