Toshiba e-studio 4511 error code CEB0
  • jasonblewis
    • Jul 2008
    • 27
    Hi,
    I have a Toshiba e-studio 4511. It gets an error from time to time, CEB0.
    Can someone tell me what that means? Or point me to a list of error codes?
    Thanks,
    Jason
  • Sbarro
    • 176
    http://www.copytechnet.com/forums/to...40-errors.html
    "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
    What do you despise? By this you are truly known"
    Guess who
    • tsbservice
      Field tech
      • 8020
      Sbarro, ditto to last post.
      • jasonblewis
        • Jul 2008
        • 27
        Thanks guys.
        Jason
        • Halen
          Black developer unit lifting movement abnormality: The black
          developer unit does not move up or down normally. With a can of air, blow out the photosensors under the black developer lifting plate. If that doesn't work, remove black developer lifting clutch, rear of machine, not too hard to get to, with a can of air and the "straw" that comes with it, dip the straw into alcohol...not the kind you drink, and blow the alcohol into and around the gear and the clutch. There is also an upgrade to the cam that turns, pretty easy to install, and if that doesn't work replace clutch.
          • copyfax
            toshiba studio 2500c error code ce40 can:t cleared Please i need the errors codes list
            • crazy
              • May 2011
              • 15
              look at color registration sensor or developer metarial also you can see 08+824 which developer is problem
              • michaelc
                Field Tech
                • Mar 2011
                • 590
                Toshiba brought out a modified clutch for this machine to solve those errors. The sensors which detect the plate moving up and down are at t he front of the machine, near the gears for the charger cleaner. If they get dirty they can give you the same codes. Also try updating the firmware, sounds daft but it sometimes helps.
                It didn't say that I couldn't do it in the manual.
