Toshiba 1310 UA Code reset?
  • imaginGuru
    Its been a long time since I serviced these (Toshiba 1310), now I'm with one showing a UA code (I think it has to do with the initial mode program or something) problem is that I don't remember how to erase it.
    By the way the equivalency of this machine is the Toshiba BD 3910 and it is in the INTRAVIA 4th Edition (which I don't have,, murphy's law I guess, I have all intravias from 5th to 13th, but not 4th...).
    Thanks for your inputs on this...
    imaginGuru
  • tsbservice
    Field tech
    • 8020
    It may not apply but on 2060 code is 08-51.Select 0 to deactivate UA mode.
    This one is much older and i will dig deep in my books and let you know if find something.
    • dbrownlee
      • Sep 2005
      • 197
      Try holding clear and 9 while powering on, or make sure 05-95 is set to 0. Hope that helps, Dave.
      GO TIGERS!!
