Problem hdd toshiba 450
  • IVANZUKI
    • Aug 2025
    Hello friends, someone knows since(as,like) I can deactivate the hard disk in toshiba 450 or with that code I can do it
    Thank you for the help
  • Sbarro
    • 176
    What for ??
    "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
    What do you despise? By this you are truly known"
    Guess who
    • fuseroller
      hey there mate, this machine will not work without hard drive .if mc down use 0-8 690 to format hdd, if not work then maybe new firmware, if still not work then new hard drive(dont forget f/w with new hdd.good luck
