toshiba 3530c
  • Luther
    • May 2006
    • 682
    toshiba 3530c
    Went on a call this morning for "time for maintenance 0070" can not for the life of me find 0070 anywhere, went to pm support and the only thing that needed replacement was the rear ozone filter,reset the counter and 0070 is still there, check every manual i have and cant find it anywhere, anyone see this code before?
  • ivovb
    • 695
    Re: toshiba 3530c
    It is YMC drums. Check SH - PM display contents (ch 5.2.3.).
    BR
    I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
      • 23007
      Re: toshiba 3530c
      The simplest way to handle these messages is to print off the 9S-103 report. It shows all the standard maintenance parts, the current count towards yield, the yield, drive count towards yield, and drive yield.
      The short explanation is that you will get a Time for Maintenance message based on copy count yield or drive count yield, just like Konica Minolta. The idea is that on very low volume machines that spend additional time idling up and idling down, you can fairly accurately predict parts replacement/yield.
      Once you've replaced the desired parts, reset specific counts in 6S-2, developer stir if you replace developer, and color calibration. Just look at the Adjustment section of the handbook. =^..^=
