s-Studio 255se Lack of response
  • Dustp115
    • Mar 2015
    • 11
    Re: s-Studio 255se Lack of response
    Originally posted by Lorenzohe
    After doing the 3+C on the HDD now getting an sram initialize screen but it is not initializing ... how can this be skipped etc
    When you get the the screen try hitting the hard key Interupt
    Also try SRAM initialization (08-9960) and (08-690)
    • drolfe@webmail.co.za
      • Sep 2012
      • 69
      Are you 100% sure that you loaded the correct firmware as it sounds identical to when we had loaded the 4ccd instead of the 3ccd. We had to send the scanner boaed away to get reprogrammed with the jig. Out here the machine have a yellow dot or a red dot in the scanner section the red is 3ccd and yellow is 4ccd
      • Riyadh hossain
        I think u need to initialize some settings in 0+8 mode 662,665,666,684,685,686,687,690,693,947 it will be ok . recently i solved this problem in es 452
