Toshiba e-Studio 3511 NIC reset
  • Clif
    • Jan 2007
    • 49
    Hello
    I have a 3511 in the field that drops off the network after a short time. i've checked for conflicts, network integrity, etc.
    Does anyone know how to enter simulation mode for the printer module on a 3511 and the simulation nimber to reset or initialize the printer module.
    Clif
  • talatm
    • 5
    Reset of Toshiba e_studio3511
    helloh
    You have to reset your copier with following prosidure
    press 0 and 8 semotancely and power on
    test mode will disply
    enter 669 press start
    then touch initionalize on touch panel
    it will take few seconds
    power off then on
    It's the way to reset your copier if you face any other problem in future you can mail me at my e-mail id & the id is talatsgg@yahoo.com
    thank's
    TALAT MASOOD
    FROM PAKISTAN
    • tsbservice
      Field tech
      • 8032
      It's NOT a good idea to do this code for NIC reset, instead of this you can try just 08/693 (Initialization of NIC information) returns the factory default of NIC card.
      Good luck and let me know if you have any problems with this.
      • mckinley
        Chief Twiddler
        • Dec 2006
        • 150
        don't use 08 669, unless you want to make your copier into a teapot.
        as tsbservice says use 08 693, the thing i've found is that now 3511's are getting on, the NIC's are getting a bit ropey & sometimes require replacing.
        Happiness Is The Road.
        • Clif
          • Jan 2007
          • 49
          thanks guys. yeah, i'd never initialize a copier unless I was planning to replace the main board.
          clif
