Paper size setting for es4540c icon missing
  • JVC
    • Jun 2011
    • 151
    Hello
    I have just received in a used Toshiba es4540c. The icon for changing the paper size is missing. I have checked the manual that I have and can not find a setting. I did find a setting that says to reset to factory defaults and after running that for a second I see the icon but it goes away and I am not sure how to change the size. I would appreciate any help.
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    Re: Paper size setting for es4540c icon missing
    It's probably got custom firmware loaded, just upgrade / reload the firmware & it should restore your icon
    Happiness Is The Road.
    • didi2005
      • May 2011
      • 401
      To solve the issue, u can upgrade newer firmware, or recover the Drawer icon using code 08-8712 set to "1".
      • tnrtt
        • 155
        Doesn't it ask you if the size is correct when you open and close the drawer? Mine do.
        • JVC
          • Jun 2011
          • 151
          This did the job.
          Thank you for the help.
