Toshiba 281C transfer belt removal
  • Kal
    • Apr 2015
    • 5
    Hello everyone
    I am new to this Forum and I am desperately looking for help troubleshooting my Toshiba 281C photocopier, I have bought the service manual but it is absolutely no help. recently I started having problems copying and printing, (blank copies, yellow stripe when printing, color smudge and discoloration...etc) and that all started when I had a one time paper jam.
    anyway I would like to pull the transfer belt and drum drawer out and see if it is damaged or dirty and eventually clean it or replace it...but I have no clue how to do it, I removed the screws that hold the tray to the machine's frame but it won't pull, I am assuming that this is how it should be removed since I noticed a handle on the drawer itself but I could be wrong. (pictures below)
    at this point I am about to give up, anyone please help.
    thanks a lot.
  • epintotox
    the noob one
    • Mar 2015
    • 14
    Re: Toshiba 281C transfer belt removal
    Originally posted by Kal
    Hello everyone
    [ATTACH=CONFIG]28823[/ATTACH]
    [ATTACH=CONFIG]28824[/ATTACH]
    thanks a lot.
    did you loose already the screw below the white connector on 2nd pic ?
    • Kal
      • Apr 2015
      • 5
      are you talking about the big screw right below the large connector? I didn't touch that one no.
      • epintotox
        the noob one
        • Mar 2015
        • 14
        loose the screw in the circle. after that u can pull out 1 unit
        • didi2005
          • May 2011
          • 401
          When u want to replace the drive gears, then only u feel the troublesome...
          • Kal
            • Apr 2015
            • 5
            [ATTACH=CONFIG]28825[/ATTACH]
            you are a life saviour thanks a million I have been knocking my head to get this out for 2 months.
            • Kal
              • Apr 2015
              • 5
              Troublesome just started,now I have error CF20 with a paper jam I give up
              • mckinley
                Chief Twiddler
                • Dec 2006
                • 150
                there are a number of things that can cause CF20 - Dev drive clutches worn ( Colour ) / contaminated, gears in revolver unit, teeth broken on revolver unit ( usually due to toner not being fitted correctly ) , Dev worn / missing ( Colour ) , Colour Auto Toner Sensor reference patch ( grey ) stained ( must only ever be blown clean & never touched with anything or it's destroyed ) , revolver motor worn out , revolover motor driver board fault.... that's a few of the possible causes.
                To be honest, if you were struggling to get the belt unit out, CF20 is going to be a pain for you.
                We are condemning these on a regular basis now as the termination date is approaching & parts will be hard to come by.
                Ps the paper is only jammed because the machine is throwing a call for service as the colour kicks in & that's stopping your machine in it's tracks.
                Happiness Is The Road.
                • didi2005
                  • May 2011
                  • 401
                  I still have 2 units of this monster under service contract...
                  • mckinley
                    Chief Twiddler
                    • Dec 2006
                    • 150
                    you're very lucky, on one site alone i have 14 of them & it's a 70 mile drive away, over my entire area i have 100's of them lol
                    • Kal
                      • Apr 2015
                      • 5
                      I have no problems fixing stuff around, no matter how challenging they are, the problem is finding the right info and to know what I am looking for and what does it looks like. the service manual that I got unfortunately talks about error codes, what they mean and what to do to correct them which is fine but it does not say what the "Dev drive clutches, gears in revolver unit, Toner Sensor" look like and where those parts are located, or how to get to them.
                      this is an old copier that I have in my basement that I don't really feel like paying $150/hour to get it fixed by Toshiba when I can save that money for toner supplies and parts, no offence to technicians but I just don't have that kinda money to give away.
