toshiba BD 4560 C44 error
  • lowrider
    • 38
    I really need help on this C44 error, I already have 3 machines down with this problem, it seems to be a fusing error but I replaced the entire fusing unit and the error is still there, can anyone please help and explain why this type of error occur? thanks very much ... I'm really puzzled on this error
  • Sbarro
    • 176
    Check power supply.
    "A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it"
    What do you despise? By this you are truly known"
    Guess who
    • esam ramadan
      • 199
      08 -89 set to 0 if it still check power pwd
      • lowrider
        • 38
        ok thanks , I'll try check power supply
        • _____e03_____
          C44
          Hello there!.. Try to replace power supply...
          • BomBay_BadBoy
            C44 error is an overheating error.. usually caused by dirty thermistors. But hold down [0][8] and then press 89. clear 08-89 to 0. turn off machine, turn on.
            glad to be of help
