Toshiba e-studio 163 error "C26"
  • mnyo
    • Jul 2025
    [Error Code] Toshiba e-studio 163 error "C26"
    hi
    I'm at a Toshiba e-studio 163, that give an error "C26", how do Clear the error code?
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Re: Toshiba e-studio 163 error "C26"
    Peak detection error
    Does the exposure lamp light? (Perform the output check in the test mode: 04-267)
    YES Replace the CIS unit.
    NO
    1) Check if the connector of the CIS unit are disconnected.
    2) Check the MAIN board if the connector (CN6) is disconnected and the harness is short
    circuited or open circuited.
    3) Check if the conductor pattern on the MAIN board is short circuited or open circuited.
    4) Replace the MAIN board.
    5) Replace the CIS unit.
    Some days, it's just not worth chewing through the restraints
    • ivovb
      • 695
      In more cases cleaning original glass helps...
      BR
      I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
