E-Studio CF20
  • ZeusGT
    • 271
    E-Studio CF20
    Hey guys, I just started working on toshibas and I have a Toshiba E-Studio 3511 in the field with a CF20 code when you try to copy in color mode or print in color mode. Does anybody know what this means? Thanks
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
  • mckinley
    Chief Twiddler
    • Dec 2006
    • 150
    normally it's the revolver motor at fault, check if the gear on the motor is gold coloured, if it is then it's the old type, the new motors have a dark grey gear. also check that no teeth are missing on the revolver unit.
    make sure it's properly cleaned out, or it will keep coming back to bite you.
    Happiness Is The Road.
    • ZeusGT
      • 271
      Hey, thanks for the advice. I will check those things out and see what's going on.
      I did some research and I found that it's an auto color sensor error. It gave a couple of things to check for... Thanks again..
