MJ-1024 Saddle Stitch Test Staple
  • 2new2no
    • Dec 2007
    • 48
    Toshiba 4511 with MJ-1024
    When trying to clear saddle stitch staple jams or replace saddle staples the unit does not preform the staple test when the saddle stitch is returned to the closed position and the finisher door is closed.
    Three draws are loaded with LT-R. Cleaned the rear saddle stitch sensor and the plastic rocker mechanism seems to function properly to trigger the sensor.
    Saddle stitch works during print jobs, just no staple test.
    Is there an output test for this?
