Hi . We have estudio c2550 it was and is working fine as copier, printer and scanner but have problem with fax.. Actualy when i press fax i cant dial numbers. Insert number button is off insert email button is off i can recive fax..but cant dial number so that cant send fax.. The did these steps
1. Check code 08- 8914 (sub) 2 - 1 (enable).
2. Change hdd and batch setting 08-8750
3. Chande sys board.
But nothing is changed.
Any help....thanks
Any help....thanks
