Toshiba E-Studio 3100c firmware
  • paperman
    • Aug 2025
    Good afternoon.
    Diagnosis - Print server is not loaded, the machine normally.
    I found on the Internet for firmware ga 1121 x3e + he also seems to be for him.
    After flashing the print server is loaded (fully functional, ping works vebinterfes, all diagnostics pass, the error is truth at the expense of CPU speed), but of course the copier does not see under it because there is no software in the firmware (which I defined file of old and new firmware + number partition is not the same).
    Sewn without having to connect to the copier -only LCD display and board.
    Judging by the file system (and did not understand what) the native firmware newer than the one that I found. You could try and restore the old system - but there's so much chaos.
    No one has accidentally system software for it?
  • paperman
    Re: Toshiba E-Studio 3100c firmware
    still need help
