E-Studio 4520C
  • aAandy
    • Apr 2012
    • 370
    E-Studio 4520C
    Hello people
    i just attended a machine with severely depleted black developer, so bad there was barely a coating on the mag roller - the drum, blade, corona & seals are all in very good condition
    i checked the machine throughout & couldn't find what would be half a kilo of developer, the client has not noticed any grit on their prints & sadly they recently replaced the waste toner collector, so i couldn't check if it had found its way in there
    has anyone any experience with this problem? the drum units are all the same age but the colours have no depletion problem
    i intend on simply replacing the developer, but i'd hate to have the client call me back about the same problem in a few months
    any pointers would be very much appreciated
    thanks in advance
    Andy
  • arnh79
    • 468
    Re: E-Studio 4520C
    That's a pretty typical symptom for that series of machine. Make sure to check that the main charge block doesn't have a broken pin where the needle electrode mounts to it. You can usually tell it's broken if you move the cleaning rod and there's a lot of slack as the cleaner moves back and forth. It will feel very different then moving the other cleaning rods. If that's ok, then you can go ahead and replace developer, grid, and main charge. I always do drum and blade at the same time since they're fairly cheap.
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • aAandy
      • Apr 2012
      • 370
      Re: E-Studio 4520C
      thanks for this - ended up fitting a new imaging unit as developer is not available in Australia
      by the way, can you tell me what the codes are for
      control panel administrator code
      05 service mode code
      thanks heaps
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        Re: E-Studio 4520C
        Should still be able to get developer in Aus. I still have it in stock.
        You will need the 05 mode to initialize the developer and perform image quality and forced line position adjustments.
        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
        • aAandy
          • Apr 2012
          • 370
          Re: E-Studio 4520C
          i couldn't find it anywhere - perhaps i can purchase through you? if so private message me with your info
          i entered 05 mode, but it asked for a code - any idea what that code is? i have the service manual but it doesn't seem to provide the code
          please advise
          thanks heaps
          • harisjameelpk
            • Feb 2015
            • 23
            Re: E-Studio 4520C
            Hi there can any one help me with the error ca50 in Toshiba e studio 853 how to resolve ? Thanks
            • jonezy999
              just one copy??
              • Feb 2010
              • 952
              Re: E-Studio 4520C
              please advise
              thanks heaps
              K Dev p/n 6LH47952000 - D-FC28-K
              05-2400 initialize all developers
              05-2401 Y
              05-2402 M
              05-2403 C
              05-2404 K
              05-2406 YMC
              05-2742
              05-4719 Both image related adjustments.
              Think that's all there is to it from memory.
              • didi2005
                • May 2011
                • 401
                Re: E-Studio 4520C
                I think e4520c is EB3 model which is using 3 digit code…
                05-204 for black…
                • jonezy999
                  just one copy??
                  • Feb 2010
                  • 952
                  Re: E-Studio 4520C
                  Yep, think you are correct. My mistake.
