toshiba E-351c operation panel frozen
  • dustzona
    • Mar 2015
    • 83
    have a operation panel that looks OK ,after coming to ready you are unable to use any buttons or touch screen . Copier shows no service codes and I am unable to get the machine to go into service mode.
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: toshiba E-351c operation panel frozen
    Format the hard drive and update the firmware
    It didn't say that I couldn't do it in the manual.
    • dustzona
      • Mar 2015
      • 83
      thanks for the info . It was a problem with the op panel. i replaced it and now copier is working.
      • djbass
        • May 2008
        • 161
        I would have suggested the same, sometimes you can get a stuck button or foreign matter under the touch panel that will cause the display to appear frozen.
        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
        • copierbuddy
          Hi format HDD and reload firmware may work.
