DC700i external fiery controller
  • adeyemi
    • 378
    I reloaded the external fiery controller of this xerox dc700i successfully. But a few minutes after completely booting up and connecting to the machine, it goes on to shut down all by itself. What could be problem here pls?
    Dgtal
  • Milo Wilson
    • 502
    Re: DC700i external fiery controller
    What is the alpha code on the controller? Right in front of the serial number on the controller.
    • adeyemi
      • 378
      Part No: 45067747
      Serial No: T00175026
      Model: Pro80-05
      Dgtal
      • adriansto
        • 2386
        Originally posted by adeyemi
        Part No: 45067747
        Model: Pro80-05
        Must be something like BT6-xxxxxx and running Win7 Pro as operating system.
        For 700 the fiery code is MXT-xxxxx and run WinXP.
        You cant upgrade EX fiery for 700 to 700i only reloading the operating system
        • InterfaceP
          • Jun 2013
          • 488
          700i should be "BP2" if its an "MMX" it's for a 700.
          Why did you need to reload Sys Software? Are you sure it took it?
          • adriansto
            • 2386
            Scott, we talk here about standalone - external - Fiery, not bustled - integrated one.
            • adeyemi
              • 378
              Yes its an external controller, not bustled. The details in the information plate on the body of the controller is as stated above. I will repeat it here again:
              Part No: 45067747
              Model: Pro80-05
              I re-installed the controller software because it stopped booting up. After re-installing the system and user sw, the controller now boots up completely, lunches command work station but CWS does not connect with the machine. And the controller shuts down all by itself shortly after its full boot up. Pls what can i do to solve this issue.
              Dgtal
              • adeyemi
                • 378
                I am thinking that the problem is that i used a wrong software version to re-install. To be frank, i'm not sure the version i used because i used copies of the software cd's not well labelled with sw version. Can someone out there advise on the correct sw version and/or (possibly) help out with a copy. Thanks.
                Dgtal
                • adeyemi
                  • 378
                  Hi Milo, did you get my pm on this DC700 ext fiery sw. The code you asked for is MXT. Thanks
                  Dgtal
