Hi,
I got a DC242 in which the yellow color misaligned. It is displaced by around 2mm. The displacement is not feed direction wise but bidirection. Meaning if you are facing the machine, yellow color is displaced 2mm away from you.
Tried replacing the Drum and the ITB. Could be adjustment for ROS or the ROS itself.
Anybody could spare some solution?
