Xerox ColorQube 9201 Print Head Change
  • prismtech
    • May 2014
    • 199
    Have to do my first swap.
    Cursed un-resolving light lines.
    Any tips or tricks?
    Thanks!
    James.
  • Exok
    • Jun 2011
    • 750
    Re: Xerox ColorQube 9201 Print Head Change
    Make sure the machine is cold (30 minutes or longer powered off).
    Never touch the surface of a print head (even when its cold).
    • acfife
      • May 2012
      • 63
      Any tips or tricks?
      Thanks!
      James.
      Make sure you dont touch the print head face plate, also check the new print head takes the same type ribbon cables.
      New style parts:
      Printhead: 604K83790 Wave Amp Cable: 117E37140 Video Cable: 117E37130
      Original style parts: The printhead is no longer available!!!
      Printhead:
      604K61672 Wave Amp Cable: 604K61410 Video Cable: 604K61420
      • prismtech
        • May 2014
        • 199
        Thanks guys!
        It went just fine!
        Two quickies if you are still around:
        Can you mix type A and type B heads on one IME?
        How much of a difference does the epoxy kit (tag 17) make to head longevity?
        Thanks!
        • Exok
          • Jun 2011
          • 750
          You can have a mix of type A & B. The only important part is making sure you have the correct cables for the type you are installing.
          Don't know about the epoxy kit. Never used it.
