Error code 042-326 Docucolor 240
  • vlaros
    • Oct 2011
    • 26
    Hi,
    My DC240 has error 042-326. I've changed the IBT belt but I can get the error to stop appearing.
    The issue is that I can't use the touch screen on my UI because is not working anymore.
    Is there a way to get rid of this error without the touch screen of UI?
    Please help
  • xcopytech
    • Aug 2006
    • 1794
    Re: Error code 042-326 Docucolor 240
    Only if you have xerox pws and diagnostic software for dc240
    • adriansto
      • 2387
      Nu este nevoie de laptop pws. Ai nevoie de softul de diagnoza pt aparat pe care il instalezi pe un PC cu WinXp sau s-ar putea sa mearga si pe Win7 versiunea 32 bit. Conectezi PC-ul la copiator prin cablu usb si ai acces la nvm-uri si ka setarile de service
      • vlaros
        • Oct 2011
        • 26
        Mersi pentru raspuns.
        Imi poti spune unde gasesc softul de diagnoza, cum se numeste sau mi-l poti da sau macar un printscreen sa stiu ce caut
        Mersi
        • lion_heart
          • Jun 2014
          • 174
          Originally posted by vlaros
          Hi,
          Please help
          there is a video and tutorial on how to fix the touch screen UI. interfacep a user in this group has it up if i remember, you can utube that vid. worked for me. as far as i know, the error need to be cleared via UI after 3 unsccesful tries. look for the instructions on fixing the ui
          • adriansto
            • 2387
            Trimite-mi un mail - stoadis@gmail.com si iti arat
            Eu il am dar nu-l dau pe gratis; il vind daca doresti sa dai bani.
            • mkdirs
              • Oct 2014
              • 177
              GO TO NVM location 741-105
              AND RESET TO 0
              Xerotk.com
              xerox copier technician
              • InterfaceP
                • Jun 2013
                • 488
                AND RESET TO 0
                His UI isn't functional.
                • mkdirs
                  • Oct 2014
                  • 177
                  Ok understand
                  just tray this
                  Xerotk.com
