Xerox 560 with Creo CX250 Stuck on startup for 10 minutes
  • Codex
    • May 2008
    • 703
    [Misc] Xerox 560 with Creo CX250 Stuck on startup for 10 minutes
    Hello
    i have a strange problem with a Xerox 560, when i start the machine , for the next 10-15 minutes the touchscreen is insesible and none of the HArdware butons works, than after a while evrything works fine for the rest of the day......the problem happens only if i turn off and on again......i tried to start up the machine without Creo and the problem disappears....i think it's a Creo problem. Any ideas??
    Memento Audere Semper
  • adriansto
    • 2387
    Re: Xerox 560 with Creo CX250 Stuck on startup for 10 minutes
    Try contact cleaner at the Creo cables that connect with machine - male and female parts.
    Also you can try to clean the queues and reformat mirror disk on Creo.
    • Codex
      • May 2008
      • 703
      Thank you
      I'll try it
      • xcopytech
        • Aug 2006
        • 1794
        I think that c560 should use Creo cx560 print server.
