compatible finisher 550
  • croma
    • Oct 2014
    • 87
    I have a finisher for the series docucolor, it is also compatible with the color 550 or 700i
  • mkdirs
    • Oct 2014
    • 177
    Re: compatible finisher 550
    yes compatible
    Xerotk.com
    xerox copier technician
    • croma
      • Oct 2014
      • 87
      are you sure? They have said that we need to change the logic board because it is not compatible
      • InterfaceP
        • Jun 2013
        • 488
        Yes and no. They look similar but they are different Docucolor finishers have a square top front cover, the 550/560's have a rounded one. Likely you have a serial # prefix PNX or a PNB (professional/ advanced). The 550/560 uses a XVE and XVG.
        Or you may have a TKX (Light Production) that wont work on the 550 either, you would need a YBF for that.
        They will work on the 700/700i/770 though.
        Furthermore, GXP, GXU and DTX are all older Docucolor finishers that work ONLY on the Docucolor series and not on 700/700i/770.
        Happy printing..
        • croma
          • Oct 2014
          • 87
          I have a PFN...it accept what type of printer?
          • InterfaceP
            • Jun 2013
            • 488
            PFN? I couldn't find anything. If you open the door it should be on the top portion of the inside.
            Likely is will work on the 700i but not the 550.
