black lines are coming and have cleaned drum unit coronas then also it is coming continously wht to do..img-904200628-0001.jpg
xerox 5790 black solid lines
Re: xerox 5790 black solid lines
You are loosing charge. The charge applied to the drum repels toner. If you installed a new drum and still have the problem, inspect and reseat the charge corotron cable going from the drum to the HVPS. If that looks fine, install a new High Voltage Power Supply.Comment
