Wc4250 false toner not installed
  • SDtech619
    • Dec 2013
    • 40
    Hi all,
    ive gone through 2 toners already and it keeps saying to reinstall toner or its set incorrectly....HELP.
    Fault codes: 09-600 and 07-500
    Thanks ahead of time.
  • Flash
    • 378
    Re: Wc4250 false toner not installed
    Pull out the toner and drum cartridge and push in on the spring loaded gear that drives the toner cartridge. If it does not spring back it is bound up and needs replacing.
    • SDtech619
      • Dec 2013
      • 40
      Hi Flash, thanks for the reply. It was actually the drum...went ahead and replaced it and worked like a charm. Thanks!
