xerox wide format 6204
  • ahmed abdou
    • Feb 2014
    • 45
    [Error Code] xerox wide format 6204
    hello
    i have xerox wide format 6204
    i can't connect with the machine using hyperteminal screen blank
    thanks
  • technogeek2009
    • Mar 2011
    • 167
    Re: xerox wide format 6204
    Not sure why you would want to connect to the 6204 using Hyper Terminal in the first place. The 6204 is available with two different types of controller. The external controller has a serial connection that is used when reformatting the hard drive and other diagnostic functions. However, an application called PuTTY is recommended when connecting using that port. Hyper Terminal is too slow for use with that port.
    • ahmed abdou
      • Feb 2014
      • 45
      the machine is B P S CONTROLLER INTEGRATED
      CODE ERROR 123-314
      I CAN't connect with serial cable
      nothing in the screen
      • ahmed abdou
        • Feb 2014
        • 45
        CODE ERROR 123-314
        CODE ERROR 123-314
        • technogeek2009
          • Mar 2011
          • 167
