Fortunately I found out what the problem was in my Xerox 7535 that has been giving me so much trouble. Turns out that the cooling fan on the power supply is going bad and if I give it a "kick start", it will run and the machine will boot up and come to ready. I was able to test the copier and run all the tests I needed to. I ran the calibrations and everything looks really great. The copier has an ultra low meter of only 56,144 total black and color. 45,000 being on black and white only.
Ok, my question is does anyone have the part number on the cooling fan that goes on the low voltage power supply? Is this the same fan that also cools the power supply on the 7345 family?
Thank you guys so much for your help.
