fault code 117-325
  • Piper
    • Apr 2011
    • 74
    fault code 117-325
    I have a Xerox Color 560 giving me fault code 117-325. This was after adding a postscript kit R1 in the ESS.
    Later, I discovered that the kit was for a WC 7346 and not for C560. The fault code is not there in the EDOC .
    The fault log has 117-310, 117-325 & 016-242 codes. What can be done to reset the fault?
  • adriansto
    • 2368
    Re: fault code 117-325
    If you have saved a previously nvm restore it - dc351
    • Piper
      • Apr 2011
      • 74
      [QUOTE=adriansto;491111]If you have saved a previously nvm restore it - dc351[/
      The NVM reset has not cleared the fault.
      • croma
        • Oct 2014
        • 87
        It solves the problem? I have the same error ...
        • Jibes_Tech
          • Aug 2016
          • 11
          Pls am having the same problem and the CE is not coming up again! Pls help me out?
