DocuColor 2060 paper jam 8-198
  • harispek
    • Aug 2013
    • 9
    [Jamming] DocuColor 2060 paper jam 8-198
    Hi all,
    i have this error code from tray 3,
    A4 format runs fine but larger than that paper stops in aligner-registration area and 8-198 code "Image Lead Out of Range "
    .From tray 1 & 2 runs fine.
    Paper is not damaged and there is no obstruction in paper path.
    I have PWS and diagnostic tool.
    Per bulletin i did folowing:
    1. Initialize IOT and IOT-PWBA
    2. Set NVM to following values
    from 742-001 to 742-010 = 80 (default 100) First Side Tray 1/2
    from 742-060 to 742-066 = 80 (default 100) First Side Tray 3
    for duplex only 742-071 = 90 (default 100) One value only
    Still the same..
    Any idea what to do next?
    HEEEELP PLEASE
  • xtrain
    • Dec 2012
    • 233
    Re: DocuColor 2060 paper jam 8-198
    The RAP says to run DC685 regicon for registration, and adjustment 7-4 feed timing. The sensor on the IBT belt, (Home 2), must be synced with the registration sensor for all trays.
    • harispek
      • Aug 2013
      • 9
      Thank you for your reply.
      I did run RegiCon and passes all routines from top to bottom,
      the last one , dc684 fails with code 6-655 .
      Also i did take out MOB sensor assy and clean it.
      I did Paper Path Timing ( 30 prints each ) and it fails on nr. 13 with code 1-160 from tray 3.
      Also i get 8-160 from tray 3 .
      • harispek
        • Aug 2013
        • 9
        • harispek
          • Aug 2013
          • 9
          View image: dc684 error
          View image: dc726
          View image: dc726 error
          View image: regicon error
          • harispek
            • Aug 2013
            • 9
            other then 8-198 code i get also 8-160 code from tray 3.
            Paper A4 80g runs fine.
            Anyone?
            • harispek
              • Aug 2013
              • 9
              Anyone please?
              • Ignis
                • Aug 2010
                • 28
                Hy, I have same problem with me 2060. At firs it start jamming every cca. 10 prints, now it wont print any A3 or SRA3 from tray 2/3. A4 paper prints just fine without jamming. I have PWS. Have you find solution?
