Xerox Color 570 errors 116-334 and 116-312
  • jmandassociates
    • Sep 2008
    • 186
  • Jake2o
    • Dec 2007
    • 325
    Re: Xerox Color 570 errors 116-334 and 116-312
    Machine 2 for certain thhis is what the error code means
    An error was detected in the HDD encryption key during activation.
    Procedure
    • Switch the power Off, then On. If the problem still exists, perform the following:
    • Refer to the Initialize Hard Disk Procedure in UI Diagnostics. Listed below
    • If the problem still exists, replace the HDD ( PL 11.6).
    • When the system has been recovered, set the HDD encryption key.
    This routine initializes Partition A of the HDD. Partition A contains the following data: added fonts, forms for ART EX, ART IV (optional), PC-PR201H, ESC/P, and HP-GL/2 (optional), ART IV User Defined Data, and SMB folder.
    Initialization Procedure
    Enter UI Diagnostic mode (see Accessing UI Diagnostics). Select Initialize Hard Disk. The Partition A radio button appears.
    Select Partition A then select Start.
    A confirmation message appears. Select Yes.
    A message indicating the completion appears. Select Confirm.
    This completes the initialization of Partition A.
    Still working on the first machine error code i don't have it in the manual.
