Square Fold Trimmer
  • InterfaceP
    • Jun 2013
    • 488
    Square Fold Trimmer
    I have a customer that needs a new blade on his Square Fold Trimmer. I cant find the part # anywhere?? Called Xerox parts and they couldn't find it either.
    Does anyone have a Part # or better yet the service manual or the EDoc?
    Thanks as always..
  • xtrain
    • Dec 2012
    • 233
    Re: Square Fold Trimmer
    Thanks as always..
    Part # is 037K01280, Trimmer Blade Assy. for squarefold trimmer. Repair procedure says it is a two man job to replace.
    Good luck finding one.
    • InterfaceP
      • Jun 2013
      • 488
      Thanks for the info. New Part # is 604K51611 but at $3,700 from Xerox for the kit, I think I'll use a file to sharpen it. LOL
      • xtrain
        • Dec 2012
        • 233
        I would suggest sending it to a local shop that sharpens paper cutter machine blades. The blade is hardened steel and a file may not work. Getting the blade out of the machine is a big job.
        • InterfaceP
          • Jun 2013
          • 488
          I was joking about the file. I think I'm going to replace it with another trimmer. Thanks for the info
          • jhalfhide
            • Apr 2015
            • 451
            On the xerox course, they said for the cost you may as well replace the whole trimmer.
            • InterfaceP
              • Jun 2013
              • 488
              I actually replaced the Blade assembly, I had one with a bent frame that wouldn't cut strait. It's a beast to replace.
