Xerox Workcentre 7220 won't boot up
  • lazo7
    • 51
    Hi everyone,
    I have a problem with Xerox Workcentre 7220.
    The machine doesn't boot up. After about 15 minutes of booting, the machine displays message : "the device is not available turn off the power to the device".
    Does anyone know what could be the problem. We have try'ed shutting it down,pulling out power cable, but no luck.
    Thank you in advance...
  • gnr115
    • 11
    Re: Xerox Workcentre 7220 won't boot up
    Firmware Alboot
    • lazo7
      • 51
      Originally posted by gnr115
      Firmware Alboot
      gnr115, thank you for a quick reply.
      I've managed to upload new firmware via USB drive using ALTBOOT like you suggested, but no luck, the same problem persists.
      The machine trys to boot for few minutes, than the screen goes black, and when the boot screen reapers, for the first second there are white horizontal bars
      all over the screen. Most likely it's a hardware issue ???
      Is there anything else I could do ?
      • lazo7
        • 51
        The machine is working after all.
        I just left it boot for about 20 mins after upgrade. And now its working.
        Thank you very much gnr115 ​for your help.
