xerox phaser 7500 not ready.
  • javier4065
    • Feb 2007
    • 251
    Hello , my problem is the following, when I turn on the printer , display only says xerox logo,it is not ready. What can I do to solve this problem, thanks in advance.
  • Jake2o
    • Dec 2007
    • 325
    Re: xerox phaser 7500 not ready.
    Ermm, well first call an engineer. Failing that do you get an error code at all? does the machine beep or make any other noises. can you post a picture of the screen?
    • javier4065
      • Feb 2007
      • 251
      thanks, display appears memory size, then printer turns gears but in display only shows xerox trademark, Maybe it can be any board? or maybe I must reset it
      I'm technician of copiers.
      • Apouthe Donald
        • Mar 2014
        • 82
        regarde le disc dure ou les RAM
        • xeroxsharp
          • Nov 2008
          • 270
          Disconect HDD if it is instal in printer.
          • Exok
            • Jun 2011
            • 750
            It could be software corruption. Try doing an AltBoot. Make sure the CPU cooling fan in the print controller is working & replace if it is not.
