Xerox 5745 IOT Pwb
  • jeanpaul
    • Mar 2009
    • 117
    [Misc] Xerox 5745 IOT Pwb
    Hi to all,
    Can someone help.
    I have a Xerox 5745 with color scanning that is indicating "Copy & Printing are unavailable".
    I try to do a Force Altboot using PWS, the green bars were ok for all module except the Copy/Print engine where the green bar stop about nearly half way.
    After some minites the machine indicate that Altboot fails.
    Now the machine remain with a Green Screen with Xerox logo.
    Does someone know how to flash the IOT Pwb?
    Waiting for your answer
    Thanks & Rgds
    JP
  • adriansto
    • 2387
    Re: Xerox 5745 IOT Pwb
    Change the hdd and do altboot again.
    • jeanpaul
      • Mar 2009
      • 117
      Hi, thanks for your reply.
      I have already change the hdd & do a force altboot.
      Altboot fail as the green bar for the copy/print engine stay 1/3 and does not move.
      • Iowatech
        Not a service manager
        • 3930
        Did any of the component updates fail before you saw the green bar? There should have been a number of subsystems that updated during an altboot before you saw the green bar.
        On a lighter note, when the machine says printing and copying are unavailable, it is more likely that a CRUM needs to be replaced than anything else. Did you try anything like that yet? I didn't see that in your initial post, so I'm sorry if I missed that.
        • Exok
          • Jun 2011
          • 750
          You may have a defective IOT PWB. That would have given you the original "Copy & Printing Unavailable" message to start with. Try installing a new IOT PWB and AltBoot again.
