7750 phaser calibration
  • croma
    • Oct 2014
    • 87
    does anyone know how to calibrate a phaser 7750 , from PhaserCal you can not , on the front panel lacks the command " Color Calibration " . thank you
  • Mukasa
    • May 2015
    • 178
    Re: 7750 phaser calibration
    Hello ,
    Please go google type in what you want to do.
    you will get all what you want.
    Pro
    Proc
    see
    Procedure:
    1.
    Printer Setup
    , select
    Calibration Setup
    , select
    Calibrate Colors
    , then select
    Lighten/Darken Colors
    The Color Reference Page prints. Use this page
    to evaluate the lightness/darkness of the
    image. The printer's current lightne
    ss level is displayed on the page.
    a.
    Select
    Lightness Level
    , then press the
    OK
    button.
    b.
    Press the
    Up Arrow
    or
    Down Arrow
    button to change the value from
    -5
    (lightest) to
    5
    (darkest), then press the
    OK
    button. The Color Reference
    Page automatically prints
    using the new lightness level.
    c.
    Repeat Steps a and b until you achieve the desired result.
    2.
    To complete the procedure, sele
    ct one of the following options:
    Accept Changes
    : Saves the new lightness level then
    returns to the Calibrate Colors
    menu.
    Discard Changes
    : Returns to the Calibrate Colors
    menu without saving any
    changes.
    Balance Colors
    There are three methods for balancing colors to
    prevent a primary color (cyan, magenta, or
    yellow) from overpowering the other colors:
    PhaserMatch and PhaserCal Software
    : Provides the most accurate color balance
    adjustment by using instrument-based m
    easurements. If using PhaserMatch/PhaserCal
    software, it is not necessary to perform either
    the Basic Color Balan
    ce or Advanced Color
    Balance procedures.
    Basic Color Balance
    : Provides a color balance adjustme
    nt that is appropriate for most
    printing needs. Twelve basic, visual evaluations
    are made to adjust the darkness of three
    shades of each toner color independently.
    Advanced Color Balance
    : Provides a finer color balance
    adjustment than the Basic Color
    Balance procedure. Two or more advanced vi
    sual evaluations are made to ensure that
    equal mixtures of the primary
    colors produce a neutral gray.
    PhaserMatch Color Management and Phaser
    Cal Color Calibration software provide
    instrument-based color calibratio
    n tools. These applications us
    e spectrophotometer or scanner
    measurements to achieve optimum calibra
    tion of your Phaser 7750 printer.
    PhaserCal software can be used with any Phaser
    7750 Color Laser Printe
    r and is supplied with
    Phaser 7750DN, 7750GX, and 7750DXF configurations. For more information on
    PhaserMatch and PhaserCal software, go to
    www.xerox.com/office/infoSMART
    . To order
    www.xerox.com/office/7750supplies
