Part# for a Xerox 4112 Part
  • vishop
    • Jan 2011
    • 220
    Hi guys,
    Does anyone have an idea for this. I need the part # for a gear in the shaft of 127K52900. A drive motor for the registration assy (i guess).
  • xtrain
    • Dec 2012
    • 233
    Re: Part# for a Xerox 4112 Part
    Originally posted by vishop
    Hi guys,
    The registration drive motor is 127K52950, not 127K52900, registration roll is 059K54890, 21 tooth gear is 807E21230. These are all shown in the 4127/4112 edoc parts list.
    • Mukasa
      • May 2015
      • 178
      Hi guys,
      Hi My friend check here the part no , there two gears , count how many teeth does the gear you want have.
      Item Part No. Description
      1 - Front Frame (P/O PL 13.1 Item 1)
      2 - Rear Frame (P/O PL 13.1 Item 1)
      3 - Lower Chute (P/O PL 13.1 Item 1)
      4 - Stopper Bracket (Not Spared)
      5 059K54890 Registration Roll ( REP 13.4.1)
      6 059K26170 Preregistration Roll
      7 005E18530 Coupling
      8 413W08350 Ball Bearing
      9 007E78050 Gear (36T)
      10 807E21230 Gear (21T)
      11 809E41710 Tension Spring
      12 809E52460 Tension Spring
      13 - Shoulder Screw (P/O PL 13.1 Item 1)
      14 - Registration Upper Chute (P/O PL 13.1 Item 1)
      15 - Upper Cover (P/O PL 13.1 Item 1)
      16 930W00212 Registration Sensor, Registration Skew Sensor
      17 962K59830 Sensor Wire Harness
      18 - Preregistration Upper Chute (P/O PL 13.1 Item 1)
      19 127K52950 Registration Motor ( REP 13.4.2)
      20 054K34450 Preregistration Upper Chute
      21 - Resistor Chute (P/O PL 13.1 Item 1)
      22 - Side Registration (P/O PL 13.1 Item 1)
      23 038E31060 Paper Guide
      24 130E94910 CIS Array
      25 - Bracket (Not Spared)
      26 960K29140 CIS Control PWB ( REP 13.4.3 , ADJ 2.6)
      • vishop
        • Jan 2011
        • 220
        Thanks xtrain and mukasa... very helpful...
        • vishop
          • Jan 2011
          • 220
          Hi guys,
          Here is a photo of the parts i was referring. I'm not sure if i have described it correctly. But it is the motor at the back of the machine that drives the registration assembly.Teeth on the gear only count 19. Is this it -
          807E21230 Gear?
          • Exok
            • Jun 2011
            • 750
            That is the Pre-Regisgration motor. To my knowledge you can not order just the gear. The part # for the Pre-Registration Motor is 068K56400.
            • xtrain
              • Dec 2012
              • 233
              I checked the parts list in my PWS and found Exok is right, the gear is part of the preregistration motor and is not spared separately. In the past, when I cannot find a gear like this, I take the old one to a machine shop and have it duplicated. Sometimes this is cheaper than finding the motor.
              • vishop
                • Jan 2011
                • 220
                Thank you guys, Good thing I've shown the picture, i guess i'll just have to order the whole motor then. The machine shop can be an option as well. They charge a lot though for small quantity, but not as much as the new motor's price.
                • Apouthe Donald
                  • Mar 2014
                  • 82
                  hello dear friend I would have the technical manual of the Xerox 4590/4110/4112 thank you in advance. here is my email fredonaldy@gmial.com
                  • adriansto
                    • 2388
                    Only edoc format.
                    You need to have the pws software for use this manual.
                    stoadis@gmail.com if you want it.
                    • xerodoc
                      • Oct 2018
                      • 2
                      Here is a link for the gear itself:
