xerox wc 7220 copies too light
  • javier4065
    • Feb 2007
    • 251
    hello, my problem is the following, this copier prints right but copies are not good. I cleaned the scanner, mirrors and lens,maybe I mus adjust it on service mode, The windows under the drums are clean. the top of the copy is too light and the bottom is good.What Can I do to solve it. thankz in advance.
  • popjumper
    • Oct 2013
    • 9
    Re: xerox wc 7220 copies too light
    Try to replace black developer and the toner as well.
    • Xeroxdude88
      • Jul 2015
      • 23
      Agreed. But the 7220 is better off with an entirely new drum. Where I work we don't waste time on the 72 developers because it's all one piece drum and developer.
      Clarke is my name. Troubleshooting is my game. Field service for life!
      • Xeroxdude88
        • Jul 2015
        • 23
        You could also increase the contrast, sharpness etc and then set those permanently in copy defaults
        Sent from my SM-T530NU using Tapatalk
        • Frenci
          • Feb 2012
          • 10
          Upgrade to 073 release and calibrate
          Inviato dal mio SM-N7505 utilizzando Tapatalk
