Docucolor 700i banding
  • adeyemi
    • 378
    I have a banding issue of dc700i that is regular and equidistant at about the diameter of the dev mag roll and only on yellow. It is cross directional, not in the process direction, pls see image attached. I have tested with several parts from another working machine including: y drum unit; dev module; ibt assy; dev hvps for yellow; drum hvps; ym ros; all to no avail. Every suggestion is appreciated. Thanks
    Dgtal
  • Milo Wilson
    • 503
    Re: Docucolor 700i banding
    Could be the drum drive motor.
    • adeyemi
      • 378
      Yes, I thought so too. I forgot to mention that I switched it with magenta drum motor but problem stayed with yellow
      Dgtal
      • xcopytech
        • Aug 2006
        • 1794
        Did you check ymc developer drive assy?
        • Milo Wilson
          • 503
          That was my next suggestion...lol
          • adeyemi
            • 378
            No, I'm yet to check the YMC dev drive module. I'll do that.
            Dgtal
            • mickey singh
              • May 2014
              • 93
              Check dev tank just in case, swap with magenta position to check
