DC1250 - Error 9-345
  • hocks
    • Sep 2008
    • 13
    Hi all,
    I have just had a DC1250 delivered (was working in NZ) to me in Vanuatu with the error 9-345.
    I have cleaned the toner from the drum edge and checked the transfer belt as advised from the supplier, however, still no go.
    Can any one suggest anything else?
  • xcopytech
    • Aug 2006
    • 1794
    you have to check IBT cleaner retract clutch and IBT clean blade home position sensor
    • TechMate
      • Mar 2008
      • 285
      Check and re-seat the wire harness that leads to the IBT cleaner retract clutch and any harnesses that might have possibly dislodged. A common case in this error category (9-xxx) for this machine when transported to another place; or damaged while in transit
      • hocks
        • Sep 2008
        • 13
        cheers guys...
        i'll give those suggestions a go tomorrow. I'm a Ricoh tech, and first time playing on Xerox, long time looking! (long story, maybe offline some time!)
        Techmate... damaged in transit... Check out my Ricoh thread, NZD$31,000 worth of copier dropped off a forklift! LOL... dot to laugh in the islands...
        • TechMate
          • Mar 2008
          • 285
          Originally posted by hocks
          cheers guys...
          Yes, things go wrong especially when a machine is transported long distance. That's why we need insurance for these things - and I hope it's covered
          • hocks
            • Sep 2008
            • 13
            UPDATE
            Hi All...
            fixed! I thought i'd get down and dirty with the retract clutch... While getting in there, i noticed a connector was dislodged... Plugged it in and het presto! Working!... Am picking it was the photo interrupter connection... So thanks to all who helped...
            Cheers
