xerox 550 service plan
  • croma
    • Oct 2014
    • 87
    How can I change the plan to a 550 xerox, if someone has the software codes, I would buy
  • adriansto
    • 2388
    Re: xerox 550 service plan
    Isnt a code; it is a file you must upload to machine via WebUI interface.
    And the file is generated by Xerox. I dont know if someone outside of the Xerox can generate this file.
    • croma
      • Oct 2014
      • 87
      ok, There is software that generates codes to stretch the floor of consumables?
      • JrTech
        • Jun 2013
        • 217
        Croma,
        Good evening. Are you looking to convert from a Metered Service Plan to a Sold Plan? Either way here it is.
        You can switch from a Metered Plan (Free supplies, they are included in a cost per copy contract) to a Sold plan (You purchase your own supplies ie Xerox.com, Ebay, OEM Connect) without a software code.
        As for going from a Sold Plan to a Metered Plan, the previous post were are correct as you need a software patch that is generated thru an internal database and is generated by serial number.
        Hope this helps let me know or PM
        • aneudimadera
          • May 2014
          • 30
          If you want to convert from sold to metered just need to save all critical nvm, then remove the battery from the MCU nvm, wait 5 minutes, put back the battery remove all sold toners inside the machine, power on the printer and synchronize the serial numbers. Install for the first time a metered toner then reload previously saved nvm. Your machine will accept metered and sold toners now.
          Enviado desde mi Nexus 6 mediante Tapatalk
          • prismtech
            • May 2014
            • 199
            That's a good one. Hope to try that some day.
            Sent from my SM-G903W using Tapatalk
            • InterfaceP
              • Jun 2013
              • 488
              I doubt this will work, the NVM are also saved in two other places so when you sync the NVM data will be re-written. With that said I have never tried this before.
              • aneudimadera
                • May 2014
                • 30
                It works, I'm doing this almost weekly, I live in Dominican Republic and the Xerox local dealers sells all those printers DMO sold and the customers wants to convert to metered because is the most easy toner to find on the internet.
                • aneudimadera
                  • May 2014
                  • 30
                  The nvm for service plan is a read only stored in the MCU nvm, when you removed the battery it resets to worldwide neutral.
                  • prismtech
                    • May 2014
                    • 199
                    Sweet!
                    If you pull the same batt in a colorqube the meters go back to 0.
                    Thought supplies might be the same....
                    • aneudimadera
                      • May 2014
                      • 30
                      I just tested the procedure in color production printers.
                      • InterfaceP
                        • Jun 2013
                        • 488
                        Please inform on what machines it worked on.
                        • aneudimadera
                          • May 2014
                          • 30
                          Xerox 700, C75, J75, 550 family, C60 family. I'll try in V80 soon. You are interface printers texas???
