Xerox 5890 fuser chip going to 0
  • ROGGER
    • Jul 2025
    I have a workcentre 5890 and the fuser chip and the xerographic unit chip are going to 0 within 4,000 copies or prints.
    We have already change the iot board, reset the machine, change the principal motor and upgrade the software
    any idea where the problem is?
  • shaikh.faiz
    • Jan 2008
    • 11
    Re: Xerox 5890 fuser chip going to 0
    I have same problem even drum chip goes to '0', even if the machine is in standby.
    If any one have solution please help.
    Thanks in advance.
    • Exok
      • Jun 2011
      • 750
      One of my techs ran into this problem a while back. Many things were tried / replaced and ultimately, the thing that fixed it was replacing the Single Board Controller.
      • shaikh.faiz
        • Jan 2008
        • 11
        Appreciate your reply, I will be very grateful if your could please tell me where the board is located.
        • shaikh.faiz
          • Jan 2008
          • 11
          Brother can you please tell me where is the controller board located, thanks.
          • SeniorTch
            • Jun 2017
            • 117
            go back side the machine see under the scanner position, remove a cover, loose a couple of thumbs screw and pull out a a housing card tray. pay attention to disconect a few conectors a tiny flat etc. good look. the big one is the SBC board.
            • SeniorTch
              • Jun 2017
              • 117
              Pardom me
              there are two tray housing card there , the upper is the IPS and memory card ,the lower is what you need to remove. you do not need to disconect the small flat cable.
              • caffeinekid
                • May 2017
                • 25
                The Peugeot man is correct, but before replacing the SBC, I would try the SD card. Machine counters are stored there as well and replacing a corrupt SD card is cheaper than the whole SBC. But beware- there is a special process and sequence for retaining print counter and serial number. Maybe someone unfortunate enough to have to work on this model can detail it. I don't remember anymore.
                • shaikh.faiz
                  • Jan 2008
                  • 11
                  Thanks and appreciate both of you for the response, was waiting for this eagerly, I will check and update.
                  • umerfarooq
                    plz send me the picture or video of sbc board xerox 5890
                    • shaikh.faiz
                      • Jan 2008
                      • 11
                      Guys thanks for your reply and support, I have scraped the machine as there was no way out
                      • caffeinekid
                        • May 2017
                        • 25
                        Scrapping is not enough. With the 58XX, you must immolate so that it never plagues another.
