Xerox C60/C70 fc 42-323
  • knightfall
    • Jul 2006
    • 633
    [Error Code] Xerox C60/C70 fc 42-323
    greetings to all,
    has anyone experienced this code and resolved for black drum motor failure.
    I have replaced the following
    drum & drum bearing
    drum motor drive assembly
    developer housing & material
    mcu pwb
    lvps
    initialized iot
    upgrade and downgrade firmware from original of 60.10.93
    increase maxprt
    any idea is appreciated, I am out of ideas.
    thank you,
    Get your facts first, and then you can distort them as much as you please.
  • seximibabay07
    • Mar 2013
    • 59
    Re: Xerox C60/C70 fc 42-323
    Originally posted by knightfall
    greetings to all,
    drum & drum bearing
    mcu pwb
    lvps
    initialized iot
    increase maxprt
    thank you,
    Hi
    here the informations that you need.
    042-323 Black Drum Motor Drive Fault
    BSD9.1 Drum K Drive Control
    Description
    Initial Action
    • Check that the Front Cover is closed.
    • Turn the power Off then On.
    • Ensure that the Xero/Dev. Drawer Unit is installed correctly.
    Procedure
    Execute Component Control [042-008 Drum Motor K: 320mm/s].
    The Drum rotates for at least a moment. Yes No Unanswered
    Go to BSD9.1 Drum K Drive Control and troubleshoot the Drum Motor K ( PL 1.1).
    Check around the Drum Cartridge for binding or extra loading.
    The Drum Cartridge loading is normal. Yes No Unanswered
    Remove the Drum Cartridge and/or the cause for extra load ( PL 6.1).
    Replace the Drum Motor K ( PL 1.1). If the problem continues, replace the Drum Motor K PWB ( PL 1.1). If the problem persists, replace the MCU PWB ( PL 11.1).
    • InterfaceP
      • Jun 2013
      • 488
      Leave the back door open when initializing the drum motor, an impact from the rear sometime will cause the back to rub the motor cap, not allowing it to rotate. Also check the connections from the IOT to the MCU. And I do see you didn't check the IOT. Good luck.
      • knightfall
        • Jul 2006
        • 633
        thanks to all the good ideas
        • ktxerox
          • Mar 2009
          • 229
          Hi is your machine is with FFPS ?
          Reg,
          kt
